Re: Copper Electroplating & Power Supply
On the power supply
yes you do use one for copper plating but the size is not as important as how long you will leave
the piece in the tank depending on the typ of copper you are using I will not assume so this is what I will say if you are using acid copper it will build up much faster
Jim Eaton
