Thread: Pin Holes
Old 11-28-2007, 11:24 PM
baz baz is offline
baz has a spectacular aura aboutbaz has a spectacular aura about
Default Re: Pin Holes
Originally Posted by fredmc View Post
I am doing a test of Columbia Super Clear Coat on polished aluminum.
I polished a piece of thick aluminum and cleaned it with Prep &Clean. I then shot a coat of powder on it, baked it at 375 for 15 minutes(according to directions). The finish is full of pinholes.
So I applied another, heavier coat of powder and baked it again for 15 minutes and its still the same, if not worse.
I am using a HF gun.
What usually causes this?
Thanks
Fred
Fred Mc.
could be from outgasing , or from water in your air line.
fix for outgasing problem: before you powder the part . put it in the oven for about 40 minutes at 25 to 50 degrees over the temp tht you will actually cure the part.
fix for water in air line is simply to get a good filtering system
baz
http://www.polissagepb.com
