Old 11-29-2007, 11:10 PM
CarWiz's Avatar
CarWiz CarWiz is offline
Default Re: Dual Thermocouples ???
Use a double pole double throw (DPDT) switch to select the TC. This could pose a problem though if the TCs are a little off in resistance between them. The PID can be calibrated for a particular TC but switching between two could throw the PV temp off a little. Try it and see if it works. The worst case is that one may read a few degrees different.
