Re: Hey guys.....
It's pretty big roughly 8x8x8. It has 4" mineral wool in all walls including floor and when I fired it up fora test run it came up to temp 400 degrees in about 20 minutes. I never did get a chance to completely finish it because we moved. I Srink wraped it and stored it for a year outside but now it is in inside storage but I still cannot hook it up because of power limitations.
It has one big door that needs to be re-installed the hinges need to be remounted. When I installed them I was by myself and the door almost fell on me so I welded them where I could get them. They just need to be flipped around and wouldn't take long to grind them off and re-install them one at a time the right way. The air pipe is on the outside and needs to be insulated and attached from the fan to the air box.
It has three big electric burners mounted in the floor. I'll have to check the wattage because I can't remember how big they are but they are enough to do the job. Maybe I'll take some pics and post them but mainly I was wondering what to ask for something like this.
