  #9 (permalink)
Old 11-30-2007, 09:31 AM
blackcote blackcote is offline
blackcote
Send a message via AIM to blackcote Send a message via MSN to blackcote
Default Re: Black turns bronzy black
Originally Posted by acidrain
it ALWAYS has to be 68F-70F.
acidrain ALWAYS gives excellent advice, but this statement I have to disagree with. your ideal temp depends on a number of factors from my experience. Right now we're running 70-72 degrees at 6ASF and having no problems, in fact if we go down to 68-70 we start having dye absorbtion problems (I assume becuase pore size is too small, but that's just a guess) It sounds that if your losing dye in the sealer your pore size is definately too big. So lowering the ano temp should help. Definately heat the dye up. it helps get it down into the pores it seems. If you still decide to send it out to get done, you have a pm.
Justin Martin, VP
Blackcote
RR1 Box 116
Liverpool, PA 17045
www.blackcote.com
blackcote@pa.net
