Old 12-01-2007, 12:52 AM
Empire03 Empire03 is offline
Empire03 is on a distinguished road
Default Re: Need a list please.
Originally Posted by acidrain View Post
You have a pretty good list... first though, is your PS capable of at least 15v? 20v preferably (minimum)?
I prefer a storage bin for the ano tank... they are rectangle, and hold parts better than round buckets.
3gal buckets work good for the other solutions. 2gal buckets or bins work good for starter dye tanks.
You can get by without the heaters if you have a large canning pot and a camp stove. Put water in the pot and heat buckets of solution placed in the hot pot double boiler style. It heats quickly, and is cheap.
Pick up a digital thermo from Harbor Freight.
You could skip the Caswell stripper and use lye. With some practice, it's safe.
You'll need some degreaser. Caswell's SP degreaser works well, but will dull gloss parts a bit.
You'll also need:
Racking (I suggest skipping the aluminum wire, and go right to titanium)
Agitation (at least a fish pump)
Rinse water... you can buy gallons of distilled water, but at $1 per gallon, you'll quickly burn up the money you could be spending on a reverse osmosis system. Look on eBay.
Sprayer for rinse water... pick up a small hand-held pump-up sprayer from the garden department.
Scrub brushes... toothbrushes work well for general outside stuff, but you'll also need an assortment of inside brushes.
How about bead blasting and buffing equipment?
Yes, it is capable of 15v I believe ill have to check that.Is there any special type of plastic that the storage bin should have.I don't have a camp stove to use.Can you tell me what all exactly needs to be heated.I know the dye and sealer but from what I have read the bath heats its self I just have to control the temp correct?I'll check out the lye and try to make it work .Any other type of degreaser that you would recommended?
I had already said to myself I was gonna use ti lol.Is the reverse osmosis system really needed.Like what exactly does it do?What is the purpose of the spray pump?Brushes aswell what are they used for?
Sorry if I sound stupid lol I just wanna get what I need ahead of time instead of having to go back and buy additional ****.
