Old 12-02-2007, 12:28 PM
Empire03 Empire03 is offline
Empire03 is on a distinguished road
Default Re: Need a list please.
Originally Posted by acidrain View Post
No stupid questions here...
Pretty much any plastic bin or bucket will work for any of the solutions except sealer. Heat your sealer in a porcelain-coated canning pot (metal affects the sealer)
The Bath will heat slightly if you are ano'ing a larger run, but you still need to start at the correct temp (do everything the same every time for repeatable results). You'll want to control the temp at around 70F, so if you are starting colder, you'll need to heat some of the bath.
RO is a good way to get distilled-like water at home. A small unit will cost ~$70. You'll be surprised how much rinse water you'll need, and running to the store for 5 or 10 one-gallon jugs is a drag. The sprayer is used to rinse into your tanks, then dunk rinse as well. That way the tossed out dunk tank water is not too contaminated, and you'll need to replace lost water from evaporation anyway. I always do both to reduce drag-over (paying special attention to screw holes, etc.). You rinse really well after every step.
The de-smut, degreaser, dyes and sealer are all heated.
The brushes are use in stripping and degreasing.
Ok,so how do you recommend heating the stuff?Propane and stove are out of the question.So all I can think of is heaters.I'm about to start buying containers for all the stuff right now.I reckon I should look for some heaters to .Is there any kind of brushes you would recommend?Also,I forgot to ask earlier what kind of buffing wheel and compound do I need?
