Re: Yet another wiring question...
Without knowing the rated capacity of the oven controller it would be difficult to say if you could wire both elements together without a problem. It would depend on the wattage of the two elements and the amp capacity of the controller.
The pid you are looking at would work in any future oven you may build. You would also likely need a contactor or SSR to drive the elements.
