Re: Yet another wiring question...
The pid is ok
(2) of the 25A ssr's you are looking at will not work with (3) 3200 watt elements. With two ssr's you would need to place 2 of the elements on one ssr. Each element draws around 13+ amps, so 2 would draw near 27 amps, to much for the 25A ssr. I would personally go with one ssr rated at a higher amp capacity.
Here is a list of things you may need depending on your design:
Hi-temp Fan
Heat sink for SSR
Screws
rivets
Hi-heat mortar or RTV sealant
Door rope seal
ceramic light socket
hi temp wire(for wiring to elements)
on/off switches(for lights, controller, fan)
terminal block(to keep wiring orderly)
wire for controller(gauge dependent on capacity)
plug & receptacle
Service cable
vent pipe
Conduit/Electrical boxes
