  #9 (permalink)
Old 12-04-2007, 12:52 AM
97Dually 97Dually is offline
97Dually is on a distinguished road
Default Re: Yet another wiring question...
Yes, I was keeping the 75%-80% loading of the SSR in mind when I figured on a 60 amp unit. If I use 3 3200 watt elements, that should be a load of around 40 amps, well within the 60 amp SSR`s "safety" zone, right ?
I do like the PID/SSR setup alot more now that I understand the differances (thanks entirely to this board) between the two. I can see nothing but positives by using this setup over a mechanical setup. I`ve only had a regular household oven so far, and see the temp`s swing quite a bit in it. Looking forward to eliminating that problem.
