Old 12-05-2007, 12:08 PM
jrow jrow is offline
Default Re: got a question for you guys.
Empire03,
Originally Posted by Empire03 View Post
alright, I have a bench grinder that takes 8x1x5/8 wheels.Well caswell doesn't sell that size so I was wondering if i could use the 8x7/8x5/8 wheels that caswell sells.If not ill just look around for the correct size.
If as you say you have a "bench grinder" the shafts may be a little short to use on anything you buff that is larger, IE, a valve cover. I would suggest that you get shaft extensions of the proper size that will except the wheel size that you want and or is available!
John
