  #9 (permalink)
Old 12-08-2007, 09:07 PM
grommit's Avatar
grommit grommit is offline
grommit will become famous soon enough
Default Re: Valve cover polishing-time and effort
i bought a tiny adaptor head for the dremel ages ago that takes sticky sanding pads, the head is semi flexible but the only thing i found is the discs flew off after a while, but boy are they good really got my time down, i have a 2" air circular sander that is really the dogs bollox, velcro pads and you can really start with the heavy grit first, these cut my time down by multiple hours, so i can look for the links and when we meet up we can talk about the discs for the dremel adaptor it made light work of all angles, defo had to wear BA using this.
tell you what pal you have done top work on the parts, the inlets are always a pain. take my hat off to you.
catch you soon
Brian
