Old 12-09-2007, 02:00 AM
acidrain acidrain is offline
Default Re: acid bath acting weird
I have regular crimp lugs on the ends of my wires, then SS screws attaching the wire to the cathode. I only had problems with connector corrosion when I used aluminum cathodes.
These are connected away from the acid of course... the cathode runs up and out of the tank.
You should be able to use your ohm meter to find any bad connections. Have you tried running a scrap piece?
