Old 09-13-2003, 01:53 AM
tbloss001 tbloss001 is offline
tbloss001
Cool.
Thanks for the info.
One of the things I'm testing out, is to heat transfer a design from a laser printer, Via heat transfering the toner onto the base metal. Then powder coating the metal. After curing, if the powder coat is resistant to xylene, I should be able to wipe off the printer toner with a xylene soaked rag.
The cured powder coat on the metal should stay, while the powder coat painted on the toner should wipe away with the disolved toner.
Haven't tried it yet, but I'm hopeful.
