Old 12-16-2007, 10:55 PM
PhredAre PhredAre is offline
PhredAre is on a distinguished road
Default Re: oven control panel
If what you are doing is just duplicating the GE oven but in a differant configuration it should work OK allowing for sound construction and proper insulation. Then on the other hand, with a little ingenuity, a person could switch a contactor with this setup, in turn, switching the elements. My experience with these newer stoves has been when the elements burn out, it causes the electronic temp controller to go out also , with that in mind make sure that yours is servicable before going to too much work.
