  #13 (permalink)
Old 12-17-2007, 03:04 PM
Tng21 Tng21 is offline
Tng21 is on a distinguished road
Send a message via MSN to Tng21
Default Re: Help!! Polishing Sandblasted Chrome.
see now thats a pretty good start ate, if you were to keep going to 600, the green polish, then pink, then your white euivilant, it will look the business.
AUtosol, are you using the normal autosol you find pretty much in all car acessory shops? Coz if you read the pack carefully, it says not to use on mirror finishes as it has a small grit in the paste which will scratch your work once its mirrored up.
The compounds arent very expensive at all and will save you bags of time and get a better finish. If you had the black emory, you wouldnt even need to sand with a 600 grit paper as 400 paper is sort of equal to emory, so you sand with 400, the emory it, then stainless ( green ) then pink, then white and your done.
Are you in the uk or elswhere?
