Re: oven control panel
Your 3 elements would be drawing about 35 amps. The controller would probably work, but you may need to change the contactor or ssr to a higher capacity unit. It's impossible to tell without knowing the limitations of the existing components.
But if you're changing to different elements and contactors/ssr's you might want to just purchase a new pid knowing everything will then be matched for size.
