Originally Posted by ringblingbelts
I have been polishing for many years and have had parts plated after polishing, but my plater has always cleaned my plates for plating. Now I am set up to do my own plating but I cannot get the polishing compound to clean off of the plates. I used the degreaser that Caswell sent me with my kits and set it up per instructions but it simply does not clean the polishing compound.
Is their some chemical I can use to remove the polishing compound before I degrease and activate the parts for palting?
Thanks in advance.
Try the plating forum. Or call a plater and ask them. Perhpas some heat would help. I've always used brake cleaner or acetone and had no problem (not for plating tho). What have you used for those many years to remove the compound between steps?
If I'm not mistaken, doesn't plating require a slightly "pickled" surface as opposed to fully show polished beforehand?
