Re: Stickey triger
Clean and lightly lube the trigger... make sure you have enough pressure going to the gun. Mine works fine at about 30-40 psi to the gun.. adjust the pressure down going through the gun with adjuster at the bottom of the gun.
If you only put 5-10 psi to the gun the trigger will never work correctly
IMHO
