Thread: Detail Sanders
Old 12-29-2007, 07:28 AM
mpierich mpierich is offline
Default Re: Detail Sanders
Originally Posted by tbreaden View Post
I am looking to buy a detail sander any looking for advice. I need it for sanding mild steel and copper plate in tight places. I see some that says they will polish? What about the sandpaper do you have to buy brand name? Thanks, Todd
I have a little Ryobi that I seldom use but it is handy. I cut triangles of sandpaper instead of using the precut ones. Coat them with rubber cement and they work fine, and I can have any grit I want that way. As for polishing, I suppose you could stick some Scotch Brite pad and/or cotton cloth on there for the last stages.
