Thread: Huge Problem
  #8 (permalink)
Old 12-30-2007, 10:04 PM
mkriegs mkriegs is offline
mkriegs is on a distinguished road
Default Re: Huge Problem
The voltage is a lot higher than what I get and I even use a higher CD than that. I had the same problem once and it turned out that the parts weren't stripping completely, but you said that's not the case.
If that happened to me I would check the different areas of the part with an ohm meter and strip and reanodize the part. but thats just me
