Old 01-03-2008, 10:46 AM
mpierich mpierich is offline
Default Re: Is it rust, or brass, and what do I do?
Originally Posted by jrow View Post
HowdeeDoodee,
If it were me I'd put a magnet of the piece and see if the original piece were steel or brass!
You could have a brass plating over steel or you could have brass pieces. The brass plating would be used under the chrome plating. I'm not sure whether you have chrome plated pieces or the plating could be nickle. Sounds more like nickle to me. All things to consider.
John
That's right, could be some copper on there as well. In any event with the pits it sounds like re=plating will be necessary.
