Old 01-07-2008, 12:09 PM
ed_denu ed_denu is offline
ed_denu is on a distinguished road
Default Re: Question About sheet metal
I used 24 ga galvanized sheet on my oven. Once you go thru an initial heat cycle the oven does not release any further fumes. Most galvanized sheet is actually zinc plating which has come to be known as electrogalvanizing. Zinc tends to melt at around 1200 degree, much higher than what your oven will be heated to.
Check your local phone listing for metal supplies or possibly hvac contractors. I found 4X10 sheets for around $50.
