Old 01-07-2008, 06:25 PM
ernst_lark ernst_lark is offline
ernst_lark is on a distinguished road
Default Re: Freezer retro-fit
Thanks for the replies.
Originally Posted by FigureLLC View Post
i would build it up on the outside like you said with 25ga steel 2x4 studs and use R15 fiberglass insulation with the kraft paper removed.
Is 4" insulation between the 2x4 metal studs the way to go? If you framed it on the 2" side, would 2" unsulation be adequate?
Also, would any fiberglass tadpole seal work, specifically the cheapest one listed at $1.80 ft.? Or should it be alittle larger?
thanks
