Old 01-08-2008, 01:04 PM
baz baz is offline
baz has a spectacular aura aboutbaz has a spectacular aura about
Default Re: Newb questions. Foggy finish. Pimpled/pitted aluminum wheels.
i would probably do 120 through 600 grit the forget the sisal wheel , use a tight stiched wheel (the ones that have a row of stiches every half inch)and a higher speed tool . your biggest problem is notonly the tools .
if its your first part you polish , give yourself a chance to practice and everything will be ok.
mpierich ,you slipped in a french word in there (BEAUCOUPS) . are you french ?
baz
http://www.polissagepb.com
