Re: Blast cabinet on the way!!!
I have the same cabinet. The nozzles are special order only as well & take approx. 2 months to arrive. order some right away if you are planning on using the cabinet often. Did you get the dust collector made for this cabinet too? the legs wobble like hell & if you put casters in the pre-drilled holes they will wobble even more. Weld some braces to the legs as support; it will prevent the wobbling. Also install a moisture trap just before the regulator. they gave me $100 off too because it was on back order for 3 months when I first bought it last year.
