Old 01-10-2008, 12:34 PM
grommit's Avatar
grommit grommit is offline
grommit will become famous soon enough
Default Learning about electrics....slowly!
hello all,
been a while since i posted about electrics it has normally been reference the fabrication of an oven. but today one of the electricians at work had a cuppa and in speak that i can understand explained about my set up and other things.
remembering i am in the UK, but i know ED DENU and the gang will be able to give sound advice as usual.
my drama is that where i intend to PC there is only a ring main circuit (one of 18 garages) each with 1 240V socket.the Electrician eventually got into my solid head that any oven needs its own dedicated line, is it 32 amp in the UK(not sure) but iam now sure that my donor parts for my oven such as the elements will not be big enough,and without its own dedicated line i am up against it secondly it is a works garage and i will not get permission to have a line fitted, if it was my property then it would not be a problem, just cost for an electrician to do the work.
any advice help to cheer me up would be appreciated.
sorry if what i wrote doesn't sound exacxtly what the electrician did actually say, but you will know exactly.
talk to you all soon,away now 300mile to pick the wife up from the inlaws,hope she is grateful i am giving up my weekend in the garage.
grommit
UK
