Old 01-10-2008, 04:59 PM
ed_denu ed_denu is offline
ed_denu is on a distinguished road
Default Re: Learning about electrics....slowly!
Wow, That's a real kick in the butt. If I understand correctly the space you are in only furnishes a single outlet which is not sufficient for your oven. If you cannot get permission from the property owners to add a circuit for the oven, then your choices are limited.
I don't recall your oven size, but would it be possible to either partition the oven off to a smaller size(for now), or downsize the elements, or both. It may take longer to heat, but there aren't a lot of choices unless you would switch to a gas burner of some sort.
