Originally Posted by mpierich
I never used it, but I assumed it was a paste or semi-liquid.
Formax website says: "Glu-Tite is gelatinous glue that is easy to apply to revolving buffing wheels."
If you hold it to a spinning wheel like you would compound, does it go onto the wheel...or is it too dried out?
I'd like to know if it works...
i have used it a couple of times and it was more the feel of a gelatinous glue.
not like a paste .if it is a bit dry it might get a bit harder (more spongy rubber like)
should be used on a buffing wheel when the wheel is new .
if you have variable speed lower the speed to avoid getting the whole tube of glue on the wall .if no variable speed (like me) i switch off the buffer and apply the glue at the same time . let me know how you like working with the stuff . i tried couple of times and did not really like it , maybe i should hve tried longer
