  #10 (permalink)
Old 01-14-2008, 08:29 PM
ed_denu ed_denu is offline
ed_denu is on a distinguished road
Default Re: New oven builder
I believe there are two grades of studs, but I ended up using the same ones you have. After the frame is built and the sheet metal skin attached it will be plenty strong. If you're going to be moving it around, just add extra supports in the floor and it will be fine.
