Old 01-20-2008, 08:20 PM
mpierich mpierich is offline
Default Re: Polishing Alum. Rims on Motorcycle
You probably went a little farther than you had to with the sanding, but it can't hurt, at least.
Slow the grinder down more than a little, with 8" wheels.
Use each compound until it doesn't get any better, then move on. Clean well between steps and use a fresh wheel for each compound.
