Old 09-25-2003, 05:37 PM
whistule whistule is offline
whistule
Ah ha. So ideally you would want to limit the current idependantly from the voltage by adjusting at the power supply but home anodisers will probably find it easier to adjust the voltage with the effect of changing the current - which should happen proportionaly but for the heating of the electrolyte which also increases current. I can now see why everyone is trying to keep the temperature of their home anodising down.
Thanks.
