Re: What is the CFM? for Powdercoating gun
Just to run the gun,, the cfm would be low I would guess about 3-5 cfm since you are using a low PSI ,, Now If you was useing a Sand Blasting it would be about 15-20 cfm YOu would have to look at the requirements on the gun find the Psi rating and tell them that,, I personally think the air compressor What kind of air compressor where you useing belt driven or oil less what brand also, where you did you buy it at
