Thread: lamp
Old 09-25-2003, 11:55 PM
non-stick non-stick is offline
non-stick
assuming you're not trying to coat a park bench, lol....that lamp should be fine for little RC car parts and what not. You'd be surprised how hot a focused 1500 IR lamp can get. It heats what it sees,basically (ergo....don't put your hand in front of them too long or you'll be surprised right quick). When one side of your part is almost cured, rotate it 180 degrees and bake the other side. Assuming that's a flat piece, mind you. OR...one can be very inventive and find an old record player, hang upside down and find some way to make an inverted turntable/carouself to hang the parts from? I dunno....never tried that one to be honest. But then again.....necessity IS the mother of invention,yes? As long as it's a low/no buck trial...I say do it all and stop at what works best for your applications. Of course..... come back and post the results for all to share, no matter how unkosher they may be. Good luck.....Russ
