Originally Posted by mkriegs
thanks, that helps a lot.
EDIT - one more question, if I'm running 2xxx and 6xxx in the same batch can I just take out the 2xxx parts 3/4ths of the way through and adjust the amps accordingly? or do they need to be run separately.
I run mixed batches with two different power sources (both PS's connected to a common cathode). I seperate out the 2xxx and 7xxx and run them on one PS, and the 5xxx and 6xxx on the other. I wouldn't attempt removing part of the batch from a common PS.
