Old 01-24-2008, 12:45 AM
warchild's Avatar
warchild warchild is offline
warchild
Default Re: Looking for feedback PLEASE!!!!
I want a fan in it cause thats what I want it to do is to heat up the air on the box like an oven does. just one of my lamps gets so hot that it's as good or I think better then an plane oven element. they did heat a big room up real good when I was just playing around with them. so I think it will heat that box up with no problem cause the heat will be stuck in that little box. My control box has everything I need in it. it's got 3 timers one for each lamp and I can set 1,2 or all 3 lamps to shut off at any temp just like an oven so it don't get over 400deg if I don't want it to.
Im not sure when I will start this oven cause I have another job. maybe this summer I will get to build it.
WARCHILD
