You can purchase premade hooks from lots of companies or make your own. Use steel or aluminum, wire,rod or fasteners depending on your needs. If you want a real cheap one go to your local hardware store and buy a couple of rolls of stove pipe wire in assorted sizes.It's only 1 or 2 dollars for the roll. Figure out a cheap way to do it and throw the hooks away after single use for best results.
