Old 01-25-2008, 04:16 PM
MrPontiac MrPontiac is offline
MrPontiac is on a distinguished road
Default Re: Copy Cad, I want to go bigger!! Now what
68 goat, i naturally strip the body and take out idle tubes, screw bolts back into all holes with threads and glassbead the carb. Next after blowing it out, all the little passages, i use my degreaser at 140 degree,s and wash it threw and thru, after i rinse carb. with tap water usually as hot as i can stand it with rubber gloves and air dry carb after blowing it out with air. Next i drop the body into a 5% mauratic acid bathe with distilled water about 1 gal. for id say 40 sec. to a min. and then drop body into distilled water tube and dry it out again the then put carb. into my electrolyte solution for 15 min. to 18 min. 5 volts andi believe 2.3 amps. after its out i drop it into distilled bathe again & then go to the yellow cad solution and swirl the carb. around for 50 sec. to a minute, remove and let air drye. This is what i do!! Only problem im having is that the 3 gal. pale im using now is to small, carb sometimes hits the electroids, not good to do, some little niucks and crannys does not get plated, always looking for better ideas. for sure!!
