Old 01-26-2008, 09:17 AM
Tng21 Tng21 is offline
Tng21 is on a distinguished road
Send a message via MSN to Tng21
Default Re: Newbie with some ?'s on polishing.
greaseless is a compiund thats just like your polishing compouhnds, its just embedded with a abbrasive media. On a mop, with your bench grinder, turn it on and put the greaseless against the mop until it coat the mop. Probably best to stop and start the bench grinder a few times. Then get a hairdryer and heat up the compound on the mop, unitl it goes hard, may take a while. Then your ready to use it as a sanding mop.
I use this techique to do a lot of my sanding and it also works on the same principlpe for the little creices. I use small felt bobs on a dremel with different variants of greaseless grit and then more felt bobs to poolish in those tite spots.
Once you start using greaseless, you'll always youse greaseless
