Re: Strange controller read out?
The EEEE is an out of range error. It could be the TC or the values set in memory. Check to make sure your TC is connected correctly. It has a + and - and must match the PID terminals. I think on mine, the red is positive. If that doesn't clear the error, test your TC with a meter that reads millivolts.
The next step would be to go through all the memory locations and check the values. One of the units I got was set up for RTD input so that caused an error on start up. Can't help you with the "PASS". I know I've read that somewhere but can't find it now.
