Old 01-27-2008, 08:34 AM
Harleydad's Avatar
Harleydad Harleydad is offline
Default Re: quick fix to outgassing
Yes you can sand and recoat parts. I don't think you need to pre-heat it. Blow off with clean dry air and maybe wipe it down with rubbing alcohol. You may end up having the same issues and need to strip and start over.
For info purposes, I outgas at a temp about 50 degrees higher than the cure temp of the powder. I'm not aware of a powder that cures at 275 degrees, is that a typo?
