  #9 (permalink)
Old 01-27-2008, 06:03 PM
Harleydad's Avatar
Harleydad Harleydad is offline
Default Re: Powder coating questions
Originally Posted by TIC1 View Post
I plan on buying the caswell 50kv gun. Which powders are the best to use??
Any TGIC polyester (in the color of your choice) would be fine. Be sure the powder you chose is UV stable. Most manufacturers will tell you if a powder is uv stable or needs a clear. As far as primer, not necessary in your case. A good degrease, clean, blast, etc......... should be fine.
