  #16 (permalink)
Old 01-28-2008, 05:30 PM
acidrain acidrain is offline
Default Re: Do i need the deluxe anodizing kit for annoing pb guns?
Sswee is right on about the heat disapation.
Also, you'll want to ano all of the parts at once for a good color match. Average complete PB guns are in the 1 - 2 sq. ft. range of surface area. At 6 amps per sq. ft., you should have a PS capable of up to 12 amps.
If you're using a charger, you'll have problems hitting the voltage needs at that current, so you'll have to settle on a lower CD. Calculate your surface area, run you PS at see what you are able to get for a CD. I suggest NOT going lower than 4.5 amps per sq. ft. CD.
Practice on some 6xxx series scrap first.
