Thread: oven wiring
Old 01-29-2008, 07:21 PM
ed_denu ed_denu is offline
ed_denu will become famous soon enoughed_denu will become famous soon enough
Default Re: oven wiring
Originally Posted by jclc43837 View Post
would a ssr-60 DA with 3-32vdc input and 24-380 vac work on 220 v coming from my box im clueless when it comes to electrical devices thanks
Both these values are ranges that the device can support. The 3-32vdc input will require you to purchase a pid controller that can output a dc voltage signal within this range to drive the SSR.
The 24-380vac value means the ssr can can handle a switched voltage range between 24 and 380 volts AC. Most residential service can supply 120vac and 240vac.
With this SSR you would be limited to around 11,500 watts of heating elements.
