Thread: Fuel Tanks
Old 01-31-2008, 01:42 AM
Swampy Swampy is offline
Swampy is on a distinguished road
Default Fuel Tanks
Hi guys
1st post hope many more. I have read quite a lot of things about polishing metals, and i must there is quite a lot to it more than just meets the eye. However i have a need for some advice with polishing large aluminium diesel fuel tanks on a Kenworth truck these tanks are large capacity ie 250 gallons some round some square.. I was wondering what type of buff would be best suited to use on this type of surface. I also have a large bullbar on the front which has been sandblasted by constant roadside dirt, again with a large flat section. I see that most of the buffs i have seen here are mostly thin about 1 2" wide but a large dia. i could see that this would take quite a long time if i were to use the edge of the buff. can these be used on a angle grinder so as the larger portion of the buff be flat against the tank sides instead of the edge. I hope i am making myself clear here.. any thoughts
Thanks in advance
Swampy
