Old 02-02-2008, 04:41 AM
KCV6's Avatar
KCV6 KCV6 is offline
Moderator
Default Re: How many amps do I need to strip chrome
You will probably need more current.
How big are the parts?
What stripper are you using?
I find with an alkaline chrome strip (draino, sodium hydroxide) you need at least 250mA/square inch, 1A/Square inch will really rip it off quick. As the chrome strips off you will see the stainless steel cathode/s and the part fizzing and the solution around the item being stripped will turn yellow.
I usually hook the parts up and simply turn up the voltage untill I see the fizzing and yellow going into solution. I use car jumper leads to cope with the current.
WARNING: OLD CHROME PLATING IS HEXAVALENT CHROMIUM. WHEN YOU STRIP CHROME, YOU MUST DISPOSE OF THE STRIPPER CORECTLY.
Cheers Mark
