  #12 (permalink)
Old 02-04-2008, 10:36 PM
baz baz is offline
baz has a spectacular aura aboutbaz has a spectacular aura about
Default Re: How much do I charge to polish a 38mm carb (pix)
Originally Posted by pb_paulie_b View Post
How is that possible being the carb I did up top took more then 7 hours?
well first off . if it would take me 7 hours to do a carb i would be out of business .
how is it possible ? i have been doing polishing for i think 18 years as a full time business plus a couple more years before that as a side job . i do a couple of carbs for harleys every month , i can tell you that i have a dozen of different die grinders , 1/4 inch belt sanders , air files ,sanders
but when i do a carb all i use is a die grinder and the finl buffing on one of my buffing machine.
it is normal that if it is your first carb it takes forever to do but the next one should be faster and with time you will get faster and if you are serious about polishing you will get better tools and then after many years you will be laughing at how long it used to take to do a part .
here is what i do in 7 or 8 hours
( that is if i am not disturbed by customers every 5 minutes)
baz
http://www.polissagepb.com
