Re: What kind of sanders should I buy?....
I saw on one of the threads you posted and you said soming about using a 1/4 inch belt sander. Where did you buy it from? cause I was neaver able to find one that sounded good. Where do you buy the belts? How fine in grits do they go? What do you use on the angle die grinder?
Thanks
