  #25 (permalink)
Old 02-08-2008, 12:07 PM
baz baz is offline
baz has a spectacular aura aboutbaz has a spectacular aura about
Default Re: How much do I charge to polish a 38mm carb (pix)
Originally Posted by mpierich View Post
My shaft is heavy duty - about 4' long and the threaded end shaft is 1/2" - I bartered some polishing to get it 'cause they are expensive for my level of operation. I believe the motor is 1/3hp @ 1350rpm or so and is plenty, I never bog it down at all. I mostly use 4" or 6" razor wheels on it, also have a drill chuck to thread on the end so I can use it for any 1/4" or 1/2" tool.
One thing you can do to make it easier to use: I built a stand for it and mounted the motor on a lazy susan turntable - that way you're not constantly flexing the shaft in an S curve when you move it around.
i think its the same kind of shaft i have , i know they are quite expensive . i ll probably try it with that 1/3 hp motor i have. (that is if i get a bit of free time )
thanks for the info.
check your private messages box
baz
http://www.polissagepb.com
