Old 09-29-2003, 08:21 PM
jnbsystems jnbsystems is offline
jnbsystems
Default Anodizing Power Supply Q's
I am in the process of setting up our shop to anodize some of our products on a small production scale, and I have some questions regarding power supply requirements. I just received the "new" LCD anodizing kit, and I plan to start "playing" pretty soon!
For starters, let me say how impressed I am with the site, and with the products I have received so far. Truly top notch!
I think I jumped into this in the middle of a revolution of sorts. When I first started researching this process about 9 months ago, power supply requirements were a bit different:
At that time, I downloaded a PDF file from Caswell, Inc's website, and the basic message was: "Unlike other plating procedures, where the amperage has to be controlled. . ., Anodizing will only draw whatever current it needs from the power supply".
Currently (no pun intended. . .), the message is different, where something to regulate current is favored (as in plating). Obviously, the messages contradict each other, so I'm left wondering what to do. I don't think the physics have changed, although the methods have.
I wanted to use a "Switching"power supply I have, regulated to 13.6 Volts DC, up to 30 amps. I used it in the past as a substitute for a car battery when charging R/C car batteries.
Is this power supply suitable to use with the updated kit? Also, why the change in methods? Just curious.
Thanks in advance for any info you can provide!!
Bruce
